Used Futaba 10CG 10C 2.4ghz Fasst RC Heli Radio - 4 months o
Get rid of stuff you don`t need anymore :)
Moderator: slammers
Postby jsflysrc » Thu Sep 29, 2011 7:02 pm
Used Futaba 10CG 10C 2.4ghz Fasst RC Heli Radio - 4 months old - brand new Sanyo 700mah battery included, Charger, Manual. $350.
**** NO RECEIVER and NO SERVOS ****
See spec below:
Big, 160 x 72 LCD with backlighting, adjustable contrast & auto-off
Dial ‘n Key™ programming w/joystick navigation
15-Model memory (expandable w/optional CamPACs)
2048 resolution in FASST 10-channel mode
Enhanced airplane, heli & glider software
Smart Switch Technology™ (SST) — Logic Switches allow you to activate a function when specified switch and/or stick positions occur
Up/down on/off timer (activate by stick or switch)
Tracks service hours for radio and models
Mode 1-4 selectable (Modes 3 & 4 programmable)
Assignable functions/switches
Auxiliary channel screen — for 1-step function/switch assignment & eliminating unused auxiliary functions
2 proportional slider switches
Digital trims on all 4 main channels
Trim memory & sub-trims (all channels)
Adjustable trim steps (1-40)
Fail-safe, servo reversing & EPA
“Full Functionality” trainer system (cord required)
Flap switch (3-position)
Retract switch
Rotary Dial (3)
Adjustable Throttle Cut/Idle Down
Sticks w/length & tension adjustments
Servo cycle w/bar graph displays
Constant trim, voltage, name and timer display
jsflysrc
{ IMAGES }: 1
Return to For sale
Who is online
Users browsing this forum: No registered users and 25 guests
