Spektrum Module help.
Discussions about rotary wing aircraft...
Moderator: slammers
Postby combat_pilot » Sat Feb 12, 2011 12:25 pm
I need to know if the button on the rear of the module is a BIND/Range test button.
On my Spektrum (DX7) it specifies it, but on the module and receiver (conversion) package for my JR 8103TX it does not.
When I start a range test, standing next to the heli everything works fine. When I walk away (90+ ft) and start checking controls (pressing button in) and moving sticks, it does not. At this point in time I don’t know the distance that I lose control between heli and transmitter.
Any help in understanding what is going wrong here would be great. May I have a faulty module\receiver?
Can someone tell me where my throttle hold switch is.... I'm about to crash.
User avatar
combat_pilot
Re: Spektrum Module help.
Postby Hi-Way_man » Sat Feb 12, 2011 11:17 pm
That button on the back is for both binding and range testing. With the button pressed in I usually get about 75 feet back from the receiver before I notice any twitching. When I let the button up it goes to normal.Now I don't know if 75 ft. is good or bad. But when I fly everything is good.Check your manual over once again there should be a section about range checking.
Good Luck
So many Planes, so little time.!!!
User avatar
{ IMAGES }: 37
Return to Helicopter
Who is online
Users browsing this forum: No registered users and 10 guests
